boaterntexas
- Joined
- Feb 4, 2003
- 254
I have a 17.5' fiberglass bass boat witha 1976 115 hp merc on it, after reading some earlier post on this site I believe that my problem with hole shot and top end speed is that I'm not gettign on the "pad". The motor is about 2" too high on the boat, but I now don't think that is the problem, I have noticed that sometimes the boat will lean to the driver (starboard ?) side when on the trailer, if this happen we will realnd it and get it back in order, I doubt the previous owner ever did so, I have also notice that there is more whieght on the driver side of the boat, the driver, the console, the battery, tackle, and trim motor are all on that side of the boat near the rear. I can trim the motor up to where it is cavatating, and I can trim it to where the boat will "bounce" or jump, but it never seems to get on the "pad" ( i'm assuming this is the extension of the hole, near the tarnsome. same as planing?) so I guess I neeed a new prop with more lift ( raker?) are my assumption ignorant, or on the right track.? I'm currently runnig a 21p prop which I was told has been worked, I think they took some of the negative edge ( inward curve?) off the top of each blade? Not sure what that means.. so Should I chage pitch, or just go to a raker, or cupped prop. ?? added info, at wot I can peg over 6g's of rpms, I knwo I need to get this down, but I run heavey loads sometimes (brothers)my speedo which I don't think is good typically will read about 38 mphs at WOT with one person on the boat, there is a good and steady chage of water pressure all the way up till about 35 mph on the spedo, 5600 rpm after that the spedo chage is almost none, I can give the motor more throttel and get rpms up and past 6000 but the spee ( water pressure) doesn't seem to cahnge<br /><br /> Thank, sorry so long wided, its a boring day at work with little to nothign to do but sit and day dream about being on the lake<br /><br />Thomas
