dajohnson53
Thread starter- Joined
- Apr 28, 2004
- 1,627
21 foot aluminum river boat with V6 outboard jet and small kicker. Normally trailered and used in fresh water. Neither main engine nor kicker have zinc anodes (as far as I can see) The main engine, being a jet doesn't have a anode/trim adjuster. The kicker has no zinc either.<br /><br />I'm going to salt water for about 3-4 days later in the month. If possible, I will be mooring the boat in the local harbor for the entire time when I'm not out trolling. Alternative will be to launch and retreive every day. If moored, both engines can be tilted fully out of the water.<br /><br />Is it critical to have anodes in this situation? If so, should I actually attach them to one or both engines, or can I dangle one off the transom while moored?<br /><br />Thanks for your advice.
