1999 mercury blue water series need suggestion
offshorebob
i just bought a proline 1999 with a mercury 150xl blue water series v6 and i was just wondering if this engines are good and if they are the same thing as the saltwater series that came or the optimax series thanks i will appreciated.
darylh
Re: 1999 mercury blue water series need suggestion
I've had a 1999 Pro-line sportsman 202 with the original 99 Merc blue water series and it's worked quite well. Some folks have experienced compression problems but it's not been a problem for me. Like any outboard, though, you need to stay right on top of maintenance with these older motors and keep it sprayed down with lubricant after each use and if you go into saltwater, flush it afterwards. I'd recommend new thermostats, impeller, plugs and change all lubricants if you haven't done so.
It's been a strong motor for me and I've had no desire to switch it out. It sat for 2 years and I went out last week to start it and it fired right up. Again, maintenance is the key to keeping it strong and dependable.
Best regards
