Merc 50hp (500) Power Loss (any more thouhgts)
paddy87
early 70s merc 50hp (500) serial not on hand.My problem is hard starting cold,runs okay with just me in boat but no power when under load. Spark is good,carbs have been cleaned filter screens and pump diaphrams replaced.Could it be rings or ???? Thanks.
Fouled Plug
Ensign
Re: Merc 50hp (500) Power Loss (any more thouhgts)
Time to invest in a compression tester. $20 should get you a useable one. Check your numbers, and we'll go from there.
paddy87
Compresion 123-125 all cyl. Still having same problem,not sure year of motor serial no. 7088895. Do I have points.
ledgefinder
Ensign
Sounds like your prop's too long (too much pitch). Are you new to the boat, or did it run OK before with the same prop?
ledgefinder
Ensign
No points. You've got the 1970-74 ignition setup where the excitation & it's trigger are all in the distributor-looking thing.
paddy87
New to boat Pitch is 14 Boat is 15ft. alum. just over 60 inches across transum.
paddy87
Motor was a tiller motor converted over to seperat controls and steering, and is new to this boat, probably makes no differance.
tmcalavy
check the plug wires, each where it should be? then do a timing/synch to get the carbs synched with the timing advance. Just my 2 cents.
