Merc 135 V-6 Trims up ok, slow to trim down, pump sounds good
sag2
I have a Sea Ray with a 135 Mercury outboard. I had just replaces the stator and rectifier for a no start and charging problem. It ran great for about a mile, then when I went to adjust the trim, it would go up but not down. I stopped and checked it out. Up trim works just like it always did. When trying down trim, the motor runs, and the tilt moves just a tad, then stops moving, but the pump still is pumping. <br />I assume I have an internal leak, as occasionally it will trim down fairly quickly. I pulled the port trim piston, and checked the check valve like the Mercury manual said. It appears to be free, but looks like a double check valve, and I can't spray carb cleaner through it. Put it back in and same problem. Mercury manual says there are check valves on the tilt ram, but I assume they are in case you hit something.<br />Any ideas on what to look for next. Mercury dealer stocks the pump seal kit for $14.00, but not sure if I am looking in the right place for the problem. New trim/tilt is $960.00 from Mercury, so would like to fix it if possible.
sag2
Re: Merc 135 V-6 Trims up ok, slow to trim down, pump sounds good
Thought I might have found it, but no such luck. Pulled pressure relief valve and found middle O-ring cut. Replaced it and it worked great for one cycle. Added oil and it is back to the same problem.
JerseyJim
just a shot in the dark here, but have you greased the fitting lately? mine exhibited this behavior when i bought the boat until I pumped some fresh grease in it and ran it up and down through some cycles. Also, to get it down, you can always open the emergency release valve.
skier
This is a problem a friend of mine had. What we did is trim/tilt it all the way up and all the way down several times with my standing on the cavitation plate. It seemed to work after that. I don't know why or what the problem was to begin with but can't hurt to try.<br /><br />Good luck.<br /><br />Craig
