Mercury 1997 ELPTO
Status
Not open for further replies.
Lee Hunter
Wondering if anyone has had any experience with this year/model Merc.90 HP Am considering buying a used one Thanks
heehaw
Re: Mercury 1997 ELPTO
i just bout one last year i have been havn carborator broblems i have cleaned them over and over after i clean them it will run ok then it will drop a cylinder i dont know what to do if anyone can help please do
CharlieB
My personal boat has a 96 ELPTO 115, other than regular water pump impellers it once needed a voltage regulator/rectifier.
PRIOR to purchasing ANY outboard.....
Take along a couple of tools
spark plug wrench
variable gap spark tester
compression tester
remote starter button
jumper cables
Remove the spark plugs and look at them to see how well the burn is
Rig the jumper cables and starter button, attach the spark tester, test compression and observe the spark.
If the engine has good spark and even compression of 120 psi or better then you can be sure that the motor and ignition is in good condition.
Carbs can be cleaned, gear oil changed, impeller changed and you should have a reliable engine.
mikeneal
I have a 1999 version of same motor I bought about a year ago. Had some carburetor issues that recently solved, not really specific to the motor, the ethanol is cause. It is good basic motor IMO.
Status
