1994 Mercury 75 idles rough
kennycat1956
My 75HP Mercury idles rough and seems to smoke more than it should when idling. The engine seems to smooth out when it tops the water and appears to run good. <br /><br />I realize it is better to smoke than not. It has the oil tank on the engine. Straight fuel only in fuel tank. Also, should I remove the oil tank and pre-mix the fuel? <br /><br />My 7 yr old really likes this boat. :)
Exjake
Re: 1994 Mercury 75 idles rough
I have a 1991 75 HP, it also smokes a lot at idle, at higher rpm it cleans up and runs great. I have tried different brands of oil and checked the adjustment on the oil pump, its still the same.
