I have a 1984 V6 Merc. 150hp that is overheating. I have changed the water pump and thermostats(Even tried to run it without t-stats). I have changed the head gaskets and have good compression. I have changed the exhaust plate gaskets, and I have checked the idle valve(poppit) for blockage(spring is good and plastic valve looks fine).<br /><br />It will idle and cool fine with water coming out the pisser and water pressure about 12psi. When I get to about 1500rpm the water pressure gets eratic and then the temperature starts climbing. If I accelerate out of the hole real fast, before the engine gets hot, the water pressure goes up to about 25psi and then the temp starts climbing.(Other engine at about 10-15psi) The water pressure on this engine is totally different than my other engine once I go above 1500rpm.<br /><br />I have high water pressure and an overheating engine.<br /><br />My next thought is to replace the powerhead gasket...<br /><br />Also, I have noticed on the overheating engine that water never comes out of the two rectangular exhaust holes on the back of the engine(below the pisser-above the lower unit). On my good running engine a lot of water comes out of these.<br /><br />Any suggestions would be greatly appreciated!!! The powerhead is coming off this weekend unless somebody has a better idea..<br /><br />Thanks<br />JR
