mercury controls
skippy D
How do, people? I've just spent most of the summer rebuilding a 1970 DUO deep v . it has a mercury (500) 50hp mercury outboard on it . a little under powered if you ask me .anyways my problem is the controler that mounts to the boat by the drivers seat . the cables are sticking & the wiring is shot , shorts & crumbling wires all over the place . the controler say's mercury right on the side, thier are two levers & cables , one is for shifting gears f/n/r . the other is the throttle. the wiring harness has one big round female connector on the end that plugs into the outboard motor on the left hand side .If ayone here has one to sell or knows a boat salvage yard that might have one it would be greatly appriciated . it's a 20' boat so the cables have to be aleast 16' i think , haven't mesured them yet . Thanx in advance , skippy D
wakruem
Re: mercury controls
You may want to check on ebay.com. I have seen<br />a few on there.
skippy D
I have there's nothing right now . I want to get it in the water asap .
andrewkafp
Skippy<br /><br />I have some diagrams of the Merc control if you are looking to take apart & re-assem.<br />Got them from an Iboats member.<br />Let me know if you need a copy.
skippy D
Thanx that would be great ! anything would be a help right now . you can get my email adress in my profile or if you have a fax machine email me and i'll let you know my fax # thanx again , skippy :D
andrewkafp
Send blank e-mail to<br />andrewkafp@yahoo.com.au<br />I will reply with .pdf's of diagrams. :D
greasemonkeyozi
If all else, I have a good referance on someone who should have that used part. I would give you his name and number, but some stuborn administrator wanna be wont allow solicitating for sell, although, he would advertise ebay.<br /> If you really want to know this guy's number, email me at greasemonkeyozi@yahoo.com.<br /> P.S. If you want to know what I mean about solicitating for sell, I'm the guy that posted "I need a prop" a couple of hours ago. What a jerk.
skippy D
thanx izu , it's not the cables i'm worried about it's the wiring harness . there's shorts and bare wires all through it .cables i can get just about anywhere .
harry styles
Can someone please explain how these controls are meant to work. I think mine is not working properly. cant get full throtle. Also why is the Throtle the small lever?
OakeJ
Hello Harry
I have a 650 Merc around the same age as your 50, the small lever that is on the right side of your controls is a Throttle advance and is only used when starting the engine. The big leaver acts as both gear shifter and throttle. When the big lever is straight up and down it's in neutral, as you move it forward it first changes the gear to forward and as you continue to move forward it acts as a throttle. It works the same in reverse.
Hope i helped you out a little.
