Engine was running rough so took it in 3 months ago . They changed all the plugs and said one of the air injectors was bad. Also water found in fuel filter so they drained/strained the tank. Ran better after I picked it up. Haven't driven it much since, but the other day finally took it out again. Had to recharge batteries to start. The engine is very sluggish now and is hard to get on plane. Full throttle up I get only 3000rpm and on plane max of 4400rpm. Tops out at only 30 knots...used to get in the mid 40s. It runs smoothly but with a loss of power. Could it be the carb and if so can you add a fuel additive to a 2-stroke? Any help would be greatly appreciated. My last maintenance bill came to 800.00 dollars.
