1986 175hp merc won't idle
harris2520
I have a 1986 175hp 4.3L I/O mercruiser V6 GM MCM175, Thunderbolt IV, Alfa outdrive. It has been running great but the last time I was out it was a bit choppy so I only crused about 25mph. When I came down to an idle she shut down like I had something wrapped around the prop. I didn't. But I can't run any more except at HIGH RPMs, 1200 or higher. I pulled the carb (Mercarb 2 barrle)and did a complete rebuild on it. No help there. I'm going to try the spark plugs tomarrow.
harris2520
Re: 1986 175hp merc won't idle
Yes that was my first thought also. I forgot to say that. It was 1" low and dark green. No water, no solids, no unusual oders. Filled back up with new gear lube. Thanks.
harris2520
OK, Spark plugs replaced. Looked OK. Timing at the lowest ilde I could get was WAY BTDC. Played with timing and ilde screw to get 8o BTDC, (as per manual & id plate). Still ildeing at around 1500 rpm but nice. Goes into gear smooth in drive-way. Still it doesn't sound like a happy motor. If it stops raining here at Lake Erie I'll put it in the water and see what she does.
The Marine Doctor
It has to idle at 1500rpm's??? <br /><br />That is too high...you might have a serious problem if it will not idle lower.<br /><br />Or and air leak :) <br /><br />TMD
harris2520
Thank you Dr. I forgot everything I knew about motors as a kid. Its been a long time since I got my hands dirty. Sorry. Please see I/O repairs for the rest of the story. I figured it out once I got her in the water and played around with the mixture and idle screws.
