My son has a 1997, Merc, 60hp, 3 cyl.,on a 16.6 ft. Flats & Bay. The boat runs great at 5500 rpm, 40 mph but then very abruptly losses power<br /> and falls of plane. From that point on attaininmg full speed is very intermittent. When advancing the throttle the engine boogs. We have replaced the spark plugs, added quick clean to the 22 gal. gas tank, replaced the cartridge fuel filter, cleaned the carbs with decarb spray. The fuel bulb is still hard when the power loss happens. This problem sounds very similar to brownsongs ( member #2342 ) problem, posted on 2001-06-26, but I did not see an answer from him stating what the fix was. Any ideas.
