need info
shortie
Hi I have a skeeter starfire with a 150 mariner on it can I do a way with the oil pump and do they smoke alot? :eek:
mellowyellow
Re: need info
welcome aboard shotrie,<br />assume you mean get rid of oil pump and manually<br />mix the gas/oil yurself... sure can. <br />do a search on the subject as it's been discussed<br />several times. it's the way I would go myself.<br />that way I would always know it's gettin the exact<br />amount of oil it needs.<br />excess smoke can be from too much oil or you may<br />need a tune-up. try posting the year of the motor<br />in the future so we know what wer're dealin with.<br />good luck,<br />M.Y.
shortie
Re: need info
Thank you Mellow Yellow! The motor is a 1990 and the boat is a 1985. Let me ask you another question, my boat wont hold charge when I hook up the lights for night time fishing. What can I look for to fix the problem?
Skinsk
Re: need info
Do you mean the battery won't hold a charge while the motors running? That is, the motor is not charging the battery?<br /><br />Scott.
shortie
Re: need info
It holds charge until I hook up my lights. How do you tell if it is charging? And what is sea foam?
Skinsk
Re: need info
A simple and quick way to see if the motor is charging the battery is to hook up a Volt meter to the battery, with the motor off. The voltage should be around 12V or 12.5V. Then start the motor, and see if the voltage returns to where it was at first, and then starts to increase. Sometimes you will see 14 to 14.5 volts. but on some motors with weaker charging systems it may increase fairly slowly, and only get up to 13 volts or a little less.. <br /><br />Also, you may need to rev it up a little to get back the juice lost while starting.. <br />Voltage will also probably fluctuate with engine speed.<br /><br />Scott..
shortie
Re: need info
Thanks Scott, Ill try that. Do you know anything about sea foam?
papasage
Re: need info
use a spare deepcycle battery for lights & troling motor. papasage....................
papasage
Re: need info
seafoam is a decarb . got mine at napa auto parts
