Re: 77 merc 850 trim/tilt wiring ???
nuttin's free you have mail. Let me know if you need more info.<br /><br />The only real difference in the two and one setup is the up on a one solenoid system use the solenoid and the down is direct wired. In the two solenoid system both up and down use solenoids. I like the two solenoid system. I also have a 15amp reset able fuse in the power going to the pump. It originally came with a 30 amp fuse, but I had a switch stick onetime and like to have burn out the motor before it popped.
