Re: Annoying beep
First we need to find out what the problem is. I would pull of the cowl, and look down low on the starboard side of the powerhead. There should be a little square black box with two blue wires, a black wire, a purple wire, and a brown wire with a tracer (I think white) coming out of it. Simply disconnect the brown wire coming from the box. Make sure you have plenty of oil in the resevior, and run the motor. If you have no more alarm, then the problem is with the oil module, the foat in the oil tank, or the sensor in the oil tank. <br /><br />If you still get an alarm then it is an over heat problem, or the temp sensor in the head.<br /><br />All the oil warning module does is set a broken alarm for a low oil situation, instead of the solid alarm, which you get from an overheat. <br /><br />Scott..
