Re: 89 150HP XR4 Overheating at Idle
When you replace the water pump, there are two main concerns (or important issues). After installing the new impeller on the shaft (with the key) the pump housing will not just slide down over it... You need to turn the drive shaft clockwise and push down on the pump cover (be easy, don't want to damage the impeller). This will align the impeller blades in the proper direction and ensure that you get the proper amount of water flow.... Just follow your manual...<br />Check the direction of the blades of the impeller when you remove the old one... Looking DOWN on the impeller they ALL should point in a counter clockwise direction and not be broken or cracked...However, most likely the impeller will remain in the pump cover when you slide it up the shift shaft during removal... So if you look at it upside down they will go in the opposite direction, Keep that in mind. <br />The other issue is when you reinstall the lower unit.. I'm going to tell you right now, to get some help... You need to realign the drive shaft up into the crank. Meaning you may need to turn the flywheel to get the splines at the top of the shaft to line up... You can't do this by yourself while pushing up on the lower unit.. Also lining up the shift shafts can be tricky... You will get the drive shaft lined up first, after that be careful not to push the lower unit all the way up until you get the shift shafts lined up... Otherwise you could push the upper shift shaft up and have to start all over... You will probably easily see what I'm talking about when you get to it... Don't be afraid...
