Re: 1994 135 Merc OB wont shift in reverse
I took the advice of the marine doctor and disconnected the shifter and throttle cables, then moved the linkage back and forth a couple of times to see if it was sticking in reverse and it wasn't. So I reattached the cables and tried it at the quicksilver throttle handle and reverse popped in like their was no problem in the first place. I did this over and over again and it seemed to be ok, but I have yet to water test it. This almost seems to good to be true, all I did was disassemble and reassemble and it works! Any comments or suggestions on what happened?
