FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Where exactly is this water spraying out? Mid leg? If so this is normal..the water flow should increase as the engine heats up.<br /><br />The majority of the water is released out thru the prop.<br /><br />TMD
yea it comes out of the port hole on the back of the engine,not the hub.The reason i was concerned is because there is a slight leak "a drop now an then"at the bottom of the exhaust cover on the block.
Is the "pee hole" hose, the small telltale hose that hangs on the starboard side properly attached, or, better still, is it clear of debris? It sounds like one of these could be what explains the irregular drops you mentioned. Just a suggestion!<br /><br />Gil
