Re: 92 115 Mariner - How does the 2+2 cylinder operation work
I must admit I have forgotten which 2 cylinders turn off, top or bottom. However when I adjusted the idle mixture 2 years ago (the dealer did a poor job) there were only two carbs to be adjusted. When the engine is running on muffs you can hear sharp reports as you near 2000 RPM. I get the impression its fuel building up in the exhaust and igniting once in a while. I guess it could be a trickle from the two cut cylinders building up. The reports get closer together as you near 2000. I don't like running the engine fast on the muffs so I don't really know how it sounds on all four out of the water.<br /><br />On my 19' Regal, it would be nice if the transition occured at 1500 RPM instead. The fastest non-planing speed is affected by the engine trying to start and stop the other cylinders, its quite annoying with all the jerking.<br /><br />I was really wondering if excessive idling would run it dry of oil.
