78 Merc 900 Water trickles out at idle
kfrei
When engine idling water seems to come out erratically and under low pressure (I think) I can stop the waterflow by just touching the hole with my pinky. At higher idle water comes out steady but can still stop flow with finger. I was thinking of changing the water pump. <br /><br />If I change the waterpump should the thermostat also be changed if it has never been before?
Kenny Bush
Re: 78 Merc 900 Water trickles out at idle
What you are seeing is normal. The tell-tale is allways low, and even at a cold start it takes a while to get a trickle coming out.......You have to wait until the thermostats open up.. Many people use a water pressure guage instead of a temperature guage. Your guage will read about 3 to 5 psi at idle, and 12 to 15 at higher RPMs.
The Marine Doctor
The water at no time should stop comming out of the telltail. <br /><br />If the telltail is obstructed in anyway, it will be low on pressure. Blow compressed air into the telltail hole and hose.<br /><br />If the water does not pickup pressure it might be time to check the waterpump for wear.<br /><br />TMD
greasemonkeyozi
Dont ever run your motor if water is not coming out that "pee hole," or tail tell. If you havnt changed out your water pump this year, nows a good time to do it. These things need to be changed out at least once a year, others will tell you once every season.
