I have a 1975 85HP Merc. Have re-built both carbs, including needles, seats,& floats! Have re-built fuel pump & new water pump impellar. Replaced old internal wiring harness with new harness. Compression test,("GOOD", 120 to 125 on all 4 cyl)! Have good blue spark on all cyls!<br />PROBLEM: In tank, motor if idled below 1300RPM, when put in gear will "DIE", however at 1300RPM'S, when put into gear, will fall down to 900RPM'S but will idle in tank? Have taken boat to lake,when started in lake starter seemed to drag as if motor might be out of time,("Good Battery"),but cranked! Will idle at 1300RPM, but when put in gear, "WILL NOT RUN",BOGG'S DOWN & DIE's! Have noticed gas running out of front of bottom carb? At home noticed throttle control seemed stiff,unhooked throttle cable from motor("cable fine"),distributor stiff & hard to turn with hand? Pulled dist.& cleaned old hardened grease, now moves freely. Put back in tank & cranked,still cannot idle below 1300RPM & gas still running out of bottom carb.? ! PLEASE HELP !!!!!! AT WIT'S END !!!
