I recently completed rebuilding my powerhead which included boring all cylinders and installing new pistons, rings, wrist pin bearings, and crankshaft bearings.<br />The engine runs great except my oil pump failed during my first inwater test run.<br />I later removed the oil pump and found out the oil pump drive gear on the crankshaft failed. The only way to fix the problem is to tear down the engine again and replace the drive gear on the crankshaft.<br />I decided not to do this again and would like to bypass the oil injection system and mix the oil/fuel. How do you disable the oil pump rotation sensor on the pump shaft without disabling the alarm module? I need to trick the module to to think the oil pump drive shaft is rotating. I would prefer to keep the module since it is also used to activate the overheat warning sound.
