I recently bought a boat that had a 1986 Mariner, 135 HP motor with a bad cylinder on it. I intended to scrap the motor, but after we looked at it a little closer, it was so clean that I decided to try to rebuild it. We got the machine work done and new parts and got everything back together (our first time rebuilding a boat motor). When it came time to start the motor it took us a while to understand the manual about timing, and then when we finally got it to fire we weren't getting fire on all the cylinders, and it seemed that the missing cylinders were actually moving around. For some reason after studying the schematic, someone suggested that we disconnect the "mercury" switch. After that all cylinders started firing and the motor actually started with almost no problem, although idling a little too high (1200 rpm). When it did start it ran for less than 30 seconds and we didn't see any water from the tell tale hole so we shut it down and put in a new water pump. After getting it started the oil alarm started going off so we topped off the tank on the motor and that seemed to cure that problem. The next thing that happened was the temperature alarm. We put in new thermostats when we rebuilt the power head and had just installed the new water pump(which the old impeller was actually shreaded, and not even connected to the shaft, we then felt pretty good that we found what caused it to mess up that cylinder the first time). The motor will not run very long now without setting off the temp alarm while there is plenty of water coming from the tell tale hole and you can touch the heads and block with your hands. The water is warm and the motor is hot to the touch, but you can hold your hand on it without getting burned. Also, the temp gage on the console doesn't say hot. My main questions are.<br /><br />1. What does the mercury switch do that causes the plugs not to fire, and do I have it installed wrong, or could it be bad. After rebuilding it we might have oriented it wrong.<br /><br />2. I am at a stand still with the overheating problem. How can I test the alarm or actually find out what is causing the overheating problem.<br />(or could the 1200 rpm idle be contributing to the problem)<br /><br />Any help you guys can give me would be greatly appreciated.
