plug wires
haustow
I have a '89 mercury 70hp outboard and I'm wondering if the plug wires can be changed or if i have to buy something else which includes plug wires? I changed the caps but i don't know how to remove the other end of the wires connected to the engine. Thanks for any help.
snapperbait
Re: plug wires
Hi Haustow.. The wires can be changed without replacing anything else...<br /><br />The ends just push into the ignition coil.... give em' a pull and they'll pop right out... ;)
The Marine Doctor
Re: plug wires
I would like to add, there should be steel caps on the other end of the wires that plug into the coils. You will need new ones also.<br /><br />TMD
andrewkafp
Re: plug wires
Also, they are special leads that are not like car leads (Need to be changed regularly). They are expensive and shouldn't be replaced unless they are old, faulty or corroded.
haustow
Re: plug wires
Thank you everyone for your replies. Very much appreciated. I will let you know how everything works out with changing the wires. Thanks again.
toomanyboats
Re: plug wires
I have a question,I just got a 71 115,the plug wires look good,the question is,can I use a high grade auto plug wire ,or do i need a special one ?<br />Thanks
