australian serial chart?
dodl
Hello,<br /><br />Finally, i think i found the serial number of Mercury 500.<br /><br />There IS a place at the block where the following is stamped in:<br /><br />"full jeweled super thunderbolt H" "831-1739"<br /><br />Is the 831-1739 the serial?? If it is, i can't find it in any chart. Some postings here suggest, this could be an australian serial. Are there charts for australian models?<br /><br />Here is a picture too....<br /><br />
<br /><br />many thanks<br />martin
andrewkafp
Re: australian serial chart?
Australian S/Ns do start with 8* , but your 831* doesn't match that motor. Mine is 8055* Aust and it's a 50 (Not 500) about '81.<br /> http://www.myfishingpictures.com/watermark.php?file=527/1413DSCN1292-med.jpg <br />Your's is pre 1978 by the band colours and looks like a 1972-74. The S/N should be found on the bracket, but brackets and plates can be replaced.<br />Haven't found an Aussie Chart.. And I live there.
bubbakat
By the markings it is just like mine which is a 1972 50 h/p merc 500
dodl
Hmm, but your motor looks different...<br />Mine is kinda "rounder"...<br /><br />
<br /><br />but many thanks!<br /><br />I found another number :) <br />144035652<br />Could this be a serial? One digit too much, right?<br /><br />cu<br />martin
andrewkafp
Thats because it's a bigger motor and they had different types of covers for the different HP's<br />My motor is this one<br /> http://www.myfishingpictures.com/watermark.php?file=527/1413DSCN1292-med.jpg and is "Rounder" like yours coz it's a 50. That 1* number doesn't line up with anything.Reckon it would start with a 3* and have 7 digits.<br />Try an image search on the web for 73 merc or 72 merc and see what surfaces.
bubbakat
I'll snap some pics tommorrow and get them up and you can compare with mine
andrewkafp
Bubbacat.<br />I have no doubt that you are right. Nobody knows your motor like the you. I know every inch of mine and can spot the same year anywhere.From '72 through to '74 they look alike, but a without that S/N you can only go by the blue bands on the wrapper and the bottom cowling.
