stalling
GOBUTS2
i have a 1995 mercury outbourd motor stalls at idle when in gear and carbs seem to load up runs rough for a short time after giving more gas than clears and runs fine at higher speed
LubeDude
Re: stalling
Seems maybe that a float is sticking! Give us more to go on, Size of engine?<br /><br />LubeDude
Kenny Bush
Re: stalling
Put a couple of cans of "SeaFoam engine tune" (available a NAPA auto stores) in your gas tank and run it out... SeaFoam is a great decarbon and fuel cleaner/stabilizer. Run it through and see if it will help.
mellowyellow
Re: stalling
ditto stuck float. tap on fill bowl with but of<br />screwdriver in a pinch frees it up sometimes.<br />good luck,<br />M.Y.
GOBUTS2
Re: stalling
SORRY ABOUT THE LACK OF INFO. ON MY STALLING N GEAR AT IDLE MY MOTOR IS A 1995 MERC. 115 NEW PLUGS DONT KNOW MUCH ABOUT ITS HISTORY I JUST BOUGHT IT
Kenny Bush
Re: stalling
Run a compression check with the engine warmed up. Post back with results. After we have seen that the compression is balanced, I would ckeck "Timing and synchronization" (in your manual) and make sure everything is according to spec. Just want to make sure we are working with a "Good" powerhead....
