Quicksilver Control Box Question (Cable Connection)
Status
Not open for further replies.
bob--o
I have a 40HP Mariner w/ Quicksilver Control Box that crapped out on me. I have a new (used) box and the electrical is all hooked back up and works. What I need to know is does the throttle cable go on top, or shifter cable on top? Also is the correct (neutral) position where the detent bearing fits into the larger opening or one of the smaller positions? Is there a diagram anywhere I could look at? Any help is greatly appreciated. Thanks.<br /><br />Bob
bob--o
Re: Quicksilver Control Box Question (Cable Connection)
This would be great, but it isn't the same model control box. Thanks,<br />Any other ideas?
andrewkafp
Geez M. Y. ..<br /><br />You have a good memory... :eek: <br />This control box is the original Merc control with the black choke button on top. I got it from an iboats member ages ago and I am embarrassed to say.. I forgot who<br /><br />I actually have much clearer .pdf copies which I have sent to a few people who needed them.
alcan
Hi bob-o<br />Post your email address and I'll try and fix you up with some info.
andrewkafp
Hey..<br /><br />It may have been you ALCAN.. :eek: :eek:
bob--o
Thanks Alcan, Anything you may have would be great.<br /><br />send to <br /><br />bob4trout@msn.com<br /><br />Thanks.
alcan
Hi bob<br />You should be in business now.<br /> Yea, I don't remember either. I send this type info to so many. Accessories are one area that some after market manuals could improve on. Most do cover the most common remote controls though, especialy manuals for the larger size motors. Often the factory manual will not cover the remote in the service manual, you have to order an accessory manual or rigging manual. This will depend on the year, manufacturer,etc. The funny thing is, all the manufactures seem to change how they put out there info from time to time. It can be confusing. Good luck Guys.
Mr-d
Alcan, can you please send the file to me to? Just bought a Mercontrol box, got it all set up but scratching head how to actually hook it up to the shift/throttle my seloc manual does not cover it.<br /><br />Thanks,<br />Daniel.<br /><br />Mr.djcATzonnet.nl
Bjornis
Hi!<br />I would really apriciate a copy of those. Just bought a boat wherethe controls are sloppy. Going to open them and see what I can do about it. Just ordered a seloc manual when i read the post by mr-d. Seems like I have the control that was on mellowyellows link but they are hard to read.<br /><br />Thanks.<br />bjornis@bredband.net
RedNecker
The QuickSilver 4000 model controller requires special throttle/shift cables. I think they are only available from Merc & from TeleFlex special Merc Gen II cables. <br />The cable end connectors are different from everything else, no adapters available yet.<br /><br />My Manual did not have any wiring diagrams other than showing the connectors, not the guages or other end connections.<br /><br />I have misplaced the manual for connections of the throttle/shift cables & I need it to complete my installation. MercDealer, as usual, is no help without the $$.$$/hr fee. One hour minimum.<br /><br />If someone has the 4000 series manual please post a picture of the throttle/shift connections, I think the connectors are stacked in the same hole bracket.<br /><br />Red
zubknarf
you really should disconnect the cables from the motor end first so you can adjust them properly. the first arm that moves when you put the control box into fwd is the shift. when you lift the fast idle lever the arm that moves is the throttle
magnus420
does anyone still have a copy of this?
Status
