mercury troubles
BRIAN03
Re: mercury troubles
It sounds like a fuel problem. Dirty fuel,clogged pick up in fuel tank, check valve, fuel line restricted, bad fuel pump diaphram, dirty carbs. If the fuel system checks out. Make sure the trigger is moving with the throttle.
booka
Had the same problem! the fix was to richen the mixture at the idle mixture screws
Clams Canino
Add overpropping to the list - if there is no history.<br /><br />-W
sbasalv
g'day ! I have same engine and same problem ... eventually determined that fuel tank vent screw didn't work properly ... you never know !
