Stefan Schmitt
- Joined
- Jan 3, 2004
- 46
After getting my 35HP mercury on a stand, today I went about having a closer look at it.<br /><br />Two things I noticed:<br />a) Someone tried to pry the lower end loose and it appears they didn't succeed (They never bothered putting the nuts back on the bolts, so it just hangs there w/a 1/4" gap. There is a pry mark on one side of the lower end, nothing big though. I tried myself gently at it, but no luck. - Any tips on loosening that?<br /><br />b) I noticed that the two upper swivel bracket bolts holding the motor to the mounting bracket are severely corroded to the degree that screwing isn't possible anymore. One side is just a clump of rust. The lower ones are in good shape, i.e. no corrosion.<br />I think that the swivel bracket itself, although corroded still can be rescued, it's the bolts and the possible weakness here that worries me.<br />How do I go about replacing those bolts? (P.S. I've even thought of just grinding down to the metal and spot welding it)<br /><br />Here's a pic with some arrows to the area I'm talking about:<br />
