Part Identification
gaugeguy
Does anyone have a description or manufacturer of the water pressure sensor on the opti-max's that has a p/n of 881879-9?
dilligafda
Re: Part Identification
Where did you get that part number? It doesn't show up in the parts catalog.
gaugeguy
It is stamped on the part itself. It also has a date code of D80803. It is the sensor that runs the water pressure for the smartcraft gauges.
rickdb1boat
Looks like you're after the Water Sensor Module Assembly. What Motor, Year and Serial #?
gaugeguy
Hi Rick, that sounds like the creature. These are not my engines, they are the opti-max's that Triton uses to power its boats. They would be brand new engines, I can get you ser#'s if you need them.<br /><br />What Triton does is take out the smartcraft instruments and they use mine. They want to put a water pressure gauge on the boat, and I want to use the existing sensor, so I need to know what kind of signal this sensor puts out (resistance, voltage, etc.)<br /><br />Thanks
dilligafda
That sensor works through the ECM and will not function independantly. That same question was asked in a recent Tech class I attended. Also, that sensor provides water pressure information to the ECM for the Gaurdian system on that engine. I don't have the part number check with your local dealer for a kit to add the analog water pressure gauge.<br /><br />Hope this helps. :)
gaugeguy
Thanks dilligaf. The kit is for the standard mechanical pressure gauge (T off of the tell tale). What they are looking for is an electric gauge, and I was hoping to use that sensor. It has to put some sort of output signal to the ECM, most likely a voltage between 0 and 5 volts. That is why I am looking for the sensor or the mfg. of the sensor so I can try to build a gauge around that signal that it outputs.
dilligafda
Exactly my point. If you try to run a gauge off the sender that supplies the information to the ECM, you change the value of the sensor and the ECM will not recognize the signal it receives, showing a fault in the engine. <br /><br />Of course I may have completely missed your message that you want to run a gauge off the existing sensor, right? Or were you looking to buy a new sensor and tee it into the tell-tale and use an electronic gauge (strikes me as a lot of work).
gaugeguy
I see. Nope you read me right dilligaf. I guess I will be using a regular 30psi sender to drive the electric gauge. Thanks guys, you have been a big help. I won't look like a huge dummy when I try to make a presentation on this now.
