smithmatbaker
Thread starter- Joined
- Nov 8, 2003
- 4
2002 40 Bigfoot 4stroke efi. RPM's low at WOT-4100-4200 range. Prop is as suggested by Merc. Engine seems to run perfect, just low rpm's. Reving in nuetral causes overrev horn at 6000 indicated by tach. What happens if I remove the throttle body restrictor plate? Is that what makes it a 40 as opposed to a 50 or 60? (Along with the ECM of course.) Will it lean out too far if the restrictor is not there? Do the bigfoots just run lower rpm?
