Prop Stollen
E120B
Hey,<br /> I covererd my boat with my 50hp merc on the back and someone stole the prop off it. i was wondering wut size and pitch prop i should put on it, it's on a 17'8" bass boat that weighs about 900 pounds. any help will be appreceated
Clams Canino
Re: Prop Stollen
You gotta live in a pretty rough area if'n they steal props of little 50 horse Mercs! :D <br /><br />-W<br /><br />
Originally posted by E120B:<br />Hey,<br /> I covererd my boat with my 50hp merc on the back and someone stole the prop off it. i was wondering wut size and pitch prop i should put on it, it's on a 17'8" bass boat that weighs about 900 pounds. any help will be appreceated
Spidybot
Re: Prop Stollen
You need a tach to find the best pitch as it is important to reach recommended rpm range at wot. For your motor it's 5000-5500. To end up with only one prop you'd better find a prop shop that'll let you test a couple of props before deciding. Depending on the actual circumstances, load, rig shape and more, I'd suggest you start with a 17" or 19". You're even going to decide on prop material (alu, stainless, composite) and prop type/design. The latter can be discussed after you test run as the more sophisticated designs can solve problems (if any) with performance.<br /><br />You should even consider the risc of hitting stuff or grounds with the prop as different materials withstand damage differently.
rickdb1boat
Re: Prop Stollen
You may also want to call a prop shop and explain what boat and motor you have. Usually they cam come real close on the pitch you need.
mellowyellow
Re: Prop Stollen
I would take a look on ebay for someone listing<br />your prop for sale. hate thiefs!
