Housedoctor71282
Thread starter- Joined
- Jan 16, 2004
- 4
I have had a steady horn blow since I came back from fishing in brackish water.I flushed the engine the next day when I got home. I assume that maybe some sand or salt fouled up the cooling system. I took a water hose and back washed the line from the exit line, and the water just began to shoot out a steady stream, after I started it with the ears for running it on dry land with a water source, until I did that, the pressure just did not seem that great. Could I have a problem with the thermostat? maybe it is not opening up due to some (trash)that might be blocking up something. Also, I just learned that most suggest that you change the impeller, and i have not done so since I bought the boat several years ago. John
