spit and sputter
rbass
45 hp merc1987. ran out ofgas,sucked oil into thecarb, fixed that wit the help of about 6 setsof plugs. idles great, nuetral, good acceleratin,then when you load hr up she spts and sputters for minute or 2 then runslike a top, what do you think? rbass GETTHENET
WillyBWright
Re: spit and sputter
It'll probably go away with hard running. Any excess oil that made it into the crankcase just needs to be diluted with new gas as it's running. Should only take a few minutes at full throttle.
dilligafda
The other possiblity is that the recirculation system check valves got plugged with the oil and can't flush themselves out causing fuel to puddle in the cylinders at idle. Pull the bleed lines and check them out...... or not, your call!<br /><br />Good luck :D
rbass
thanks you guys, of corse i have not run it in a couple months ,but when this all happen was late sept, all through oct. i used the boat and had the same results, spit ,sputter then run like a big dog. so the hard running did not fix it, it has autoblend for oil, maybe rebuild carbs will help, first will check out the bleed lines. thanks again,,,rbas GETTHENET
