Question----parts still available
ryanc
Are ALL parts for a 1973 Mercury 20hp motor still available today. Including upper and lower gears and bearings? Thanks RCOBB :confused:
rickdb1boat
Re: Question----parts still available
Yes they are. Depends on what all you need and your serial number is a must. <br /><br />Try Here first(Call)1 941 351-4975 <br /><br />or:<br /><br /> web page <br /><br />There are others with the serial number that can be looked up.
ryanc
serial # 3669749 Just wondering if lower gears and powerhead gears and bearings r still available? Just wondering if investment in these old motors are worth the money. Thanks ryanc
Chinewalker
Hi Ryan,<br /> Although it's possible some new gears, etc. are available, you'd have to luck out and find a dealer who's more interested in liquidating 30-year old inventory than one who's selling at retail prices. The cost of buying new gears for your motor would be much more than the motor was worth on the open market. However, if you're planning on keeping the motor and weigh the cost against a new motor, and do the work yourself, you might come out ahead - but then you have to take into account the fact that you likely don't have the special tools required to properly disassemble the unit, you'll need a manual, you're still running a 30-year old powerhead, and it would be much more economical to either find a used lower unit, or find a similar motor and use yours for parts.<br /> As for bearings, pretty much any Mercury bearing is still available, either through a dealer or aftermarket through Kaman Bearing or the like. Take your old bearings and seals with you and they can match them up.<br /> Also, there are no gears in the powerhead - what gears are you referring to? The only gears in the opper part of the motor are the throttle advance gears and those with the shifting mechanism under the carb... neither of which strip out very often...<br />- Scott
ryanc
Thanks for your reply chinewalker i have a good lowerunit still. I have a manual now and i'm going to replace the upper bearings in the power head. I need as much help as possible. thanks rcobb
