Re: Older Merc opinions wanted
Back to the 70...........I really don't think there's a downside to having all new electronics! They're not exactly cheap!! After all we are talking about a 25-yr-old motor here, doesn't time fly!!!!<br /><br />One thing I do fer sur is to take a compression test. If the cylinders are within 5 psi of each other, you've very likely found a good motor. Best if you can run it on a boat (I'm assuming you're looking to purchase this motor ?yes?), but at least you say it starts well. Idle quality is very important, 3's that are getting 'sick' don't idle well at all. Heck, they never idled that great new, but I'm just spoiled with a Tower of Power 6.<br /><br />This should be a very economical motor, but isn't suited for use on heavy hulls. Only about 43 CI displacement and you must prop to be in the hi end of the rpm band. DO NOT lug this motor or you will certainly toast the pistons.<br /><br />Give it a decarbonizing treatment, use premium TCW-3 or better oil, and Mid or Premium grade non-alcohol fuel, and it should give you many years of reliable service. After all, as noted, it IS half of a Tower of Power. LOL.<br /><br />HTH.......ed
