Hi all,<br />Threw a rod on my 70's 115hp in-line 6 :-( so been looking around for a used motor. Have found an early 80's 150hp in-line 6. Can probably get it for $500-$700AUS ($400-$650US)<br /><br />It's been sitting for a little while but looks in reasonable shape. A quick compression test showed 110-120psi on all cylinders except #1 which had zero.<br /><br />A torch looking down hte bore of #1 showed the piston a bore looked good. Anyone know if the total lack of compresison could be from stuck reed valves/exhaust issues? And could it be simple to inspect by taking some of the side plates off?<br /><br />Is 110-120psi a decent amount of compression for one of these? My 115hp had around the same (but not so even) and it was a ***** to start.
