Clams Canino
Thread starter- Joined
- Jan 10, 2004
- 2,179
Somebody just e-mailed me for a CDI switchbox test. I wrote back and thier mail bounced - TWICE. So...here is the simple test.<br /><br />1. Turn off ignion<br />DOSCONNECT BATTERY<br />2. Disconnect all 3 wires on the distributor side of the switchbox.<br />3. Remove the HV lead from the coil to the center cap (remember it unscrews<br />from cap)<br />4. Reconnect the center lead to the COIL side only.<br />5. Position that HV lead about about 3/8" from ground (block, shrouds etc)<br />and find a way to hold it there.<br />6. Jumber the brown and white terminals on the dist. side of the switchbox<br />together.<br />RECONNECT BATTERY<br />7. Check that you have +12 V at red terminal.<br />8. Turn on ignition and verify +12V at white terminal (on red terminal side)<br />9. Touch the black terminal to ground - unit should cause spark each time<br />you touch ground.<br /><br />-W
