alittledinghy
Thread starter- Joined
- May 15, 2003
- 83
So the impeller was in pieces and i couldn't find but 3 of the impeller blades stuck in the water pump and housing. Yes i have the manual. The manual doesn't show all and i am curious if the finned piece on the port side, attached to the iron block between the cylinders and engine block which has a brass tube connecting it to the top cylinder is part of the cooling system and if i need to remove it to locate the missing impeller pieces. That is my best run on sentence to date...<br />If it is part of the cooling system, is it a thermostat or something on that order. Workin with little four stroke engines all my life has made me a little slow. Jerome
