Forceluver
Thread starter- Joined
- Aug 25, 2003
- 36
I removed the lower unit as the book describes, with the throttle in the foward postion.<br /> Problem is I can not get it to snug back up, It feels like I'm having trouble with the lower shift shaft for it is grooved, I'm thinking maybe I'm not centered with the female connection it goes into. But my other concern is that the reverse cam lock has moved around a bit and I'm not sure if its proper postion. The cam can spin a total of 360 degrees. Seeing how the contol is all the way foward maybe the lower shift shaft should be turned all the way in either direction. Thats what I do not know.<br /><br /> Please help, The fish are coming soon.<br /><br /> This might be a better way to explain,<br /> I'm just hoping there is a default postion for the shift shaft seeing how the throttle is in the forward postion. For example Since I'm in forward maybe the shift shaft should be all the way clockwise or counter clockwise. Cause it does stop either way when turninng a few revaloutions. <br /><br />Scott
