merc_650_72
- Joined
- Feb 29, 2004
- 7
Hello, I just bought a 1972 Mercury 650. It was stored in a shed on a saw horse for the last 3 years. Right before it was stored it had a tune up. Not positive what that all included, but I know it got new spark plugs.<br /><br />The engine came with no fuel line what so ever. Temporarily, just to see how it ran, I connected my fuel line from my old tank directly to the fitting that comes out of the side of the engine.<br /><br />Question #1 - Do I need a fuel filter, and if so, what kind should I get.<br /><br />Question #2 - The engine starts great and idles pretty good (slightly rough). When I shift into forward and start to throttle up, it hesitates, and I have a feeling if I hammered it, it would die out. At higher RPM's it runs perfect and I can throttle a little down and hammer it no problem. The first time I started the engine, it idled way too high so I adjusted the carbs with the two screws in order to have a lower idle. Is that the correct way to do it? It seems to me those screws are for fuel/air raios not idle speed.<br /><br />Question #3 - Can you use a carb cleaner like STP for 2 cycle engines like this and would it help?<br /><br />Thank you very much! I hope I included enough information, if not just ask. I have a manual, but I don't know a whole lot about engines.
