I have a 1988 23' Sea Ray w/ twin 135 hp.the cowl<br />covers have sea ray(light color) on them but I am told they are mercury's in disguise.<br />I'm having a problem with idle on both,but it is an ittermitten problem and does not happen to both at the same time. <br />They can be idling o.k. one minute,and then it's as if not all cylinder are firing or there is one cylinder that is fowling,then all of a sudden it will rev up like all cylinders are firing again(or the throttle was pushed) and blow out a puff of white smoke,then go back to the bogged effect,this is repeditive, then other times it will idle fine. <br />This seems to be getting worse and more often. <br />If you give it throttle and go back to idle it will run o.k. for a while and then start up again.<br />No problem with missing if motors are taching above 1500rpm But does still happen when idle in gear(slow troll) <br />Have replaced plugs,gas filters,water seperators,and checked for lose or kinked lines.Both motors were gone over by mercury mechanic a couple of season ago and checked out<br />Any Suggestions ??
