I've searched for an answer without any luck. What controls the idle speed of the Opti Max? I know the computer ultimatly does but what about the sensors. Will a bad throttle position sensor cause high idle or would it be the shift interupter sensor? The reason I ask is my motor started surging at idle then eventually started idling high(around 1000 RPM) It's a 1999 200 Opti. My manual doesn't help very much. I changed the fuel lines, water seperator, and priming bulb with no effect. The motor runs great just higher than normal Idle. Any suggestions would be greatly appreciated. thanks
