Nandy
Thread starter- Joined
- Apr 10, 2004
- 2,145
Mercury 5000 - 50 H.P. Four <br />4 Stroke<br />Motor s/n 2479050 <br />Motor built somewhere from 1965 - 79 Possibly 1974<br /><br />I had this motor for over 3 years. It always dripped water on the water exhaust port instead of shooting the most common know tattletale stream of water that most of us are use to. I thought it was the water pump. I purchase an impeller kit, installed and it will still just dripped. I researched the net and all I found was one person indicating that this was normal for this motor type and model. Last year next to the end of the season the motor did a very loud noise and stopped. It would not start again. I took it out of the water and realize that the exhaust port did not looked wet. Next time at the water the motor started ok. I look at the water exhaust while running and realized there was no water coming out.<br /><br />I took the outer exhaust plate and the inner exhaust plate out. The grooves on the outer exhaust plate were plugged with some rock like material. There was no way that the water was flowing there and coming out of either water exhaust. Anyway, I scraped the material out, put everything together with new gaskets and fire the motor with the flush attachment. No problem there, it worked like a charm, water coming out of the exhaust port like any other motor. I speed it up for short period of time just to see how it worked. I also put it on gear to make sure the shifts were working fine. I took it to the lake and there it would not start. I could see some smoke coming so I know there is some combustion. At some time the smoke appeared to come out of the lower carb. After almost draining the battery down the motor started just to die 2 seconds after. Took the motor back home and there it start on the second try. Take it back to the lake and it wont start, take it back home and it starts. Checked all over. Take it to the lake, no start. Checked there and keep trying to started. It started only when the motor was out of the water with only the prop and the water pump ports under water. It ran for about a minute or so and when I tried to accelerate it the motor died. Did this number a few times, took it home and there with the flush attachment it worked great, it will not die if I accelerate it and will not stop running.<br /><br />I am at a lost. While working on the motor initially I had it upside down for a while. I am wondering if I messed up the carburetor float but this will not explain why it wont run at the lake. Maybe it is the reed valves but I never touch them. I am using new gas and I am adding the gas stabilizer like always. There is spark on all plugs. If I check the plugs when it fails to start the plugs at the top are wet and the ones at the bottom are dry. However the lower carburetor seems to spit gas out when running. Any help will be appreciated. Sorry for the long post.
