Throbbin Rods
Thread starter- Joined
- Jan 25, 2003
- 213
I have a 7.5 HP Mercury, the word Lightning is embossed on the side iof the bnlock and there is a sticker above that that says Comet. Serial Number is 6178247. I put a new impeller in it (the old one shredded) and used compressed air to blow out all the passages then replaced the impeller and the key. Put it all together and it won't pee out the telltale, it occasionally spits but it is very sporadic. I took it apart two more times looking for an error. The water tube is properly installed. I chucked the main shaft in my cordless drill and submerged the lower unit, and under power it was pumping water up out of the output hole. I put my thumb over it and there was decent pressure behind it. I am kind of at the end of my knowledge. Any ideas? Does this motor have a thermostat? Also, can anyone tell me what year this motor is?<br />thanks very much
