Re: Need Help on 150hp Mariner
On the engine with the problem, do what waterproof suggests initally....<br />We are going to test the stator!<br /><br />You are going to have to remove the outer switchbox to get access to the inner one....<br /><br />Then, remove the blue and red wires from the top of the INNER switch box and remove the blue/white and red/white wires from the top of the outer box... Switch them from one box to another...<br />Don't disconnect any other leads to the boxes when doing this unless you have to, to get the others loose, but make sure everything is reconnected before you crank the engine... <br />After switching the above leads, crank the engine and see if the "no-spark" condition on one bank, moves to the other side. If it does, you need a new stator...<br />Good luck, and let us know...<br /><br />Don't trust ohm readings, they don't confirm anything, trust me, I know! This is the best way to determine if the stator is working properly...
