afishinado21
Thread starter- Joined
- May 2, 2004
- 11
Hello<br /><br />I have a 2000 Optimax 225 HP. Took the boat out yesterday for the first time this season. No problem starting, no problem going 5mph in the channel for 5-10 minutes. No problem throttling up to around 3500 RPM. After a few minutes @ 3500 the engine suddenly powers down to idle speed and the Check Engine light comes on. No other lights or beeps. Shifted to neutral and turned off engine. After giving it a minute tried restarting, engine started but sounded like it was about to die (very low idle), Check Engine light on, then stalls. This happened 4 more times. Let is sit for a few minutes longer while I got my seatow information out... restarted with no issues. Ran for a few more minutes @ 3500 rpm then back to the dock.<br /><br />Any ideas what could be the cause. Last season I had this problem happen intermittently a few times. More consistanly moving at idle speeds, between docks, the motor seems to hesitate almost like its going to stall. Sometimes it does when docking and shifting from forward to neutral and reverse.<br /><br />Help or information is greatly appreciated.
