Jdeagro
iboats.com Partner
- Joined
- Jul 30, 2003
- 1,682
Re: Very interesting artical about HP.
Twswinner;<br /><br />The trailer boats article showed the results on the V8 with the tabs. Although it improved (Acceleration to 30 was 10% faster, and WOT was 4.4% faster) the improvement with the 4.3 was better. This put the smaller engine running 1 mph faster at WOT than the 5.0 V8 as it picked up 4 MPH. The added weight of the V8 did not seem to be that much but it is the location of the weight that makes the difference. <br /><br />When the weight goes up the boat goes down. More wetted surface = more resistance. In the case of these two Maxum the added HP did not seem to offset the increased wetted surface.<br /><br />In the article the 375 required 23% more fuel to achieve 13% more speed. What is interesting is that the 375 only weighed 235 lbs more. Again it is the location of the weight in addition to the weight itself. Maybe we can look at it another way; it takes about 12% more fuel just to propel it's own added weight at WOT. <br /><br />You can push the numbers, question the test parameters, and many other conditions, but $800.00 per MPH, plus lower fuel efficiency is a bit expensive, especially when you rarely run at WOT for any length of time. I can tell you how to get 2 to 4 mph for under $200 and increase the MPG.
