Re: How long to warm up engine?
I cleaned the carb and it seemed to make a difference. When I disassembled the carb, I noticed a ton of crud in the filter strainer assembly on top of the carb. There also appeared to be a milky white substance (varnish?) on the bottom of the float bowl after the gas was drained out. I cleaned the carb and dried it with canned air. I also blew through the orifices with canned air. I put the carb back together and installed it back in the motor. The only concern I have is that I don't know if I attached the carb adequately to the powerhead. One of the two nuts that hold the carb body to the motor was incredibly hard to get to and unscrew / screw. I had to move a ton of stuff out of the way (choke solenoid, part of the cranking motor), but I think (hope) the carb is secure on that side of the attachment. <br /> <br />Anyway, I tried her out afterwards. Started up and ran it with the neutral throttle lever up, originally all the way up. But, this time, the RPMs were very high compared to pre-carb overhaul. So, I dropped the level to about halfway and let it warm up for about 45 seconds. I then put the lever down and it sputtered hard for a couple of seconds, but then gradually picked up and idled for about 20 seconds until it died out. This idle seemed a little rough. I started it up a second time. This time it started right away, and then I warmed it up with the neutral throttle lever up a bit for about 10 seconds. I then dropped the lever and this time it idled for about 20-30 seconds before I turned the motor off manually. <br /> <br />One other note: The idle mix screw was about 1 turn from seat prior to the carb overhaul. When I put the clean carb back together, I set the idle mix screw to 1.5 turns from seat. <br /> <br />One question: When running with the muffs on, I noticed alot of foamy gas exhaust coming out behind the prop. Is this normal? <br /> <br />Also, if anyone has any comments about the motor operation after the carb overhaul, feel free to voice them. <br /> <br />Thanks in advance.
