Re: trigger wire 78 Merc 800
Well picked up Clams.. They went to coil pack in 1979 me thinks...<br />Provide us your S/N and we can find the year, but if you find that it does have the coilpack ignition and it is the trigger wire, the answer is that as long as there is a bit of servicable wire coming out of the flywheel, both for stator and trigger, you can solder or crip a similar gauge Auto or marine wire to it. I did a few on my 1980 50hp with no problems. Just re-insulate the loom and it will run fine.<br />Check my pretty green one that replaced the corroded white wire.
<br /><br />
